Dann benutzen wir diesen Thread mal als Alesis Micron Sammelstelle
Ich neige dazu Textdateien anzulegen um Informationen zu sammeln ...
# micron -
http://alesis.com/micron
micron - Product Overview -
http://alesis.com/stuff/contentmgr/file ... erview.pdf
micron - QuickStart Guide -
http://alesis.com/stuff/contentmgr/file ... manual.pdf
micron - Reference Manual -
micron - Patches by Category -
http://alesis.com/stuff/contentmgr/file ... tegory.pdf
micron - Patches by Bank -
http://alesis.com/stuff/contentmgr/file ... k_prog.pdf
micron - MIDI implimentation -
http://alesis.com/stuff/contentmgr/file ... tation.zip
implimentation ??
http://dict.leo.org/ende?search=implimentation - spricht für die Midi Implementierung und Dokumentation
micron OS Update v1.10 -
http://alesis.com/stuff/contentmgr/file ... 10_syx.zip
Micron OS Release History -
http://alesis.com/stuff/contentmgr/file ... istory.pdf
micron Presets v1.02 -
http://alesis.com/stuff/contentmgr/file ... s_v102.zip (programs, patterns, rhythms, and setups)
# ion -
http://alesis.com/ion
ion setups v1.01 -
http://alesis.com/stuff/contentmgr/file ... s_v101.zip
ion Bank v1.01 - Red -
http://alesis.com/stuff/contentmgr/file ... 01_red.zip
ion Bank v1.01 - Green -
http://alesis.com/stuff/contentmgr/file ... _green.zip
ion Bank v1.01 - Blue -
http://alesis.com/stuff/contentmgr/file ... 1_blue.zip
ion Bank v1.01 - user -
http://alesis.com/stuff/contentmgr/file ... 1_user.zip
# FAQ
- How to wipe all programs on the Alesis Micron via MIDI instead of manually deleting them on the device itself !??!!??
-> not possible !!! You need to delete every program manually.
- How do I reinitialize my micron keyboard
-> Power on while holding: "OCTAVE DOWN", "PROGRAM", and "SETUP"
-> does NOT clear memory
- Check current firmware version or upload new OS
-> Power on while holding: "PROGRAM", and "SETUP"
# Links
Yahoo Group -
http://tech.groups.yahoo.com/group/alesis-ion/
Micron FAQ -
http://aim.alienearmusic.com/aimw/index.php/Micron_FAQ
more Sounds -
http://slam.magicshells.com/~cyberpunk/ ... n.patches/
# Software for realtime editing and to import/export patches
- micronAU (OSX) -
http://mysite.verizon.net/retroware/
- DAW Plugin (cp micronAU.component /Library/Audio/Plug-Ins/Components)
- standalone with x-code developer tools ? (not tried yet)
- real time edit via NRPG, send/receive SysEx
- micronit (OSX/Win) -
http://music.geocities.jp/icontrolit56/
- standalone
- open/save as *.mxb, *.mxt
- real time edit via NRPG, receive SysEx (does not send SysEx)
- micronizer (OSX) -
http://mrbook.org/micronizer/
- standalone
- open/save as *.mnz, *.syx
- real time edit via NRPG, send SysEx (does not receive SysEX, no GUI update, bug or not implemented ?)
- SysEx Librarian (OSX) -
http://www.snoize.com/SysExLibrarian
- MidiOX (Win32) -
http://www.midiox.com/
- How to import patches into micronit or miconAU ?
-> as MIDI source select the connected MIDI Interface (to send sounds from micron) or a SysEx program (i.e. SysEx Librarian for OSX or Midi-Ox for Win32)
- micronit: midiport - "SysEx In"
- miconAU: source for "midi in"
-> send a program with your micron "Send MIDI sysex" or play *.syx file with a SysEx program. The GUI will update itself and display the loaded program
-> save program
- micronit: click on the knob labelled "4" in the "manual" to save the patch inside of micronit
- miconAU: program is automatically saved in DAW
- How to export patches out of micronit or miconAU into micron and save as sysex to local disk ?
-> import a patch or change any parameter of current patch, "store" LED in micron will light up red, hit "store" button to write program to micron
-> open i.e. SysEx Librian (OSX) - "Record One" - "Send MIDI sysex" in micron program, save program as *.syx
- There seems to be a bug in micronAU and micronit (or maybe cannot be implemented better). Negative values for "Oszillator Octave" and "Pan" result in highest octave and panning right !
-> with micronAU edit the program (i.e. set oscillator octave -3 or panning left) and upload via SysEx. This will change to the correct values
